Thanks @Crusty181 for confirming all that I thought we may need / want. All our grief has come about because this year the 20.63-1 is the opposite of last year, so we are after the model with bed on each end, unfortunately that has led to a lot of confusion from salesman used the old model numbers quoting on last years details. So your model is now called to 20.63-2 OB.
Yesterday turned out far better than we expected with the dealer being very accommodating over the loss of confidence we had in the process so far, I am pretty sure he realised when we walked in we were about to head back out the door and he would be refunding our deposit, and he gave us a great deal in the end, and the minister for finance had a smile on her face again at the end of the meeting, so we went ahead with the purchase.
I have opted to get rid of the entertainment unit, the factory wanted to put it down in the cafe dinette area, pointless to us, that would be where we set up a lot of our outside cooking gear and after finally seeing what space we had and what it would eat into, meh, we can live without it, and I am not without a few skills to retrofit a bracket at a later date for the amount of time it will be used.
Going the solar 300w with 200AH of battery as last year on a trip for 4 days free camping in 40 deg plus heat, with the 12v fans, the tv on with ABC for kids DVD's blaring for the 3 yr old, I found the 180w,100AH I had in the camper struggling a lot.
The Anderson plug for the fridge - is that a direct feed from vehicle battery, or from a dual battery? Is the feed in the 12 pin just not heavy enough to handle the load from the 4601 unit?
I will fit the TV brackets for the dinette and the rear bed later myself, as we will transfer the tv from our old van as well as use the new one from the showpack which we got upgrade in size for nothing.
I read your thread on the Ibis, so we went the upgrade to the 3 - should work well we hope, the olds bought a Sterling last year and over xmas on the stinking days I just sent the kids down to visit them in the same park, so we are excited about that considering the temps we usually encounter here in SA.
Can I ask why you relocated bunk power points to the foot end (and what is the foot end)?
We did finally manage to get back into the model that was on display at the show yesterday, without a cafe though, and it was great to take pics and confirm in our mind what we thought we wanted where. I have been fairly anal in going over the plan details, much to their horror, PID's and design layouts are up my alley in my working life - and adding a few 12 volt points in the van for fans etc. when we free camp in the heat.
Can I ask about water filtration, we have never had it before and I was laying in bed last night and remembered about it, is it standard on these vans? Do ppl go for 1 filter under the sink or straight from the tank etc. This is an area we have no experience in, apart from filling our old van 80l tank up and having to cart water in containers previously.
Thanks for all the other information, the minister has been reading and nodding her head, so she is happy- like you we are wanting long ownership and added quite a few bells and whistles, long way from the swag and ute nowadays.
Interestingly, from prices I saw posted from the Melbourne show, they were all 3k dearer on the 20.63 OB than here at the SA show. Not sure how that works with the factory in that state and road freight etc pricing.
@Passionfingers we have last years 21.64-1 OB, which from the sound of it, it roughly equivalent to what you have ordered (with the beds at both ends).
Just to comment on a couple of your questions:
Anderson plug - You can opt to have this connected either directly to the fridge, or to the van batteries from the car. I opted to have it connected to the batteries, and rely on the 12v supply to the fridge via the 12 pin plug. I went this way as I already had a dual battery system installed int eh tug, and by connecting it in parallel to the van battery via the Anderson, it was charging as we were driving, and visa versa, the car battery is charging when we are stopped from the solar, keeping both the engel in the car and the Dometic in the van running. With regard to running the van fridge on 12v, it seems not to matter too much which way you wire it, its doesn't work all that well on 12v anyhow, maintaining the temperature at best (although even this seems to challenge it).
TV Brackets - as @Crusty181 says, you will need to get the factory to fit the tapping plates in the walls of the van so you have somewhere to mount the TV brackets. We got the factory to install the bracket (as we didn't already have one), but if you are going to install your own brackets, you'll need the mounting points put in prior.
Water Filtration - We had the factory fit an under sink water filter with a little drinking water tap on the sink. It works well, however if I was doing it again, I would get a twin cartridge filter which sits before the main water inlet so that it filtered the water to everything before it came in to the plumbing. I mat of mine recently purchased this system, and has it so it clips on just near the inlet. Others here also use the BEST in-line filters in a similar way. I'm looking to add on of these in the near future as some of the water you get in parks tastes questionable at best.
Extended Draw Bar - I didn't see you mention an extended draw bar in your list of extras. I would highly recommend this as a relatively inexpensive addition. Not only because it gives you the potential for a tool box, but mainly because of the better turning circle. Even with the longer draw bar that we have, I still need a pretty good colder-sack or similar to turn around so I don't hit the draw bar on the rear bumper of the car.
Hanging Space - Our model only has 1 long cupboard, which we kept as a pantry with shelves, however in hindsight, we would have tried to get a wardrobe in there somewhere, as we do find it difficult to store jackets and my wife's dresses in there without stuffing them in an overhead cupboard. I did see a layout which I think may be yours that had two tall cupboards, which if we had seen we would have selected, so we could have both a pantry and a wardrobe.
Good luck with it all, it sounds like it going to be a great van. Can't wait to see the pics once you get it.
