Hey Guys,
I've just taken delivery of our new to us 07 18.57.7 Outback, after selling our 07 16.49.3 outback.
I seem to be having a problem getting any cold water pressure from the tap, either on mains or tank water.
Hot water has ample pressure at both sink and shower, but cold is just dribbling at both.
I can hear the pump working fine on 12V, and it cuts in and out with using the tap on and off.
I can see a water filteration system built in under the sink, and am wondering if this may be restricting water pressure severely, assuming that hot water does not go through the filter just like at home.
Would this filter be standard fitment from Jayco, or added by an owner down the line?
I also have a small drip leak under the sink. It traps water under the rubber mat fixed to the underside of the sink. Could this be leaking from between the sink drain and sink somehow? Just after ideas before I pull this apart.
All other issues seem to be sorted at this point, so I'd love some feedback.
Darren
Darren
