Interesting.. So if you want no cupboard its $135 for the table then extras for Laminex so under $300.
Yep I got the Bunnings hinge (prestige brand I think?) and it is no good when the screws go in as it closes to far so the table doesnt sit level . I had to put screws with big heads on them to level it out but will get a better hinge down the track.For quality piano hinge in different sizes I found a Sydney company that have them.
http://www.continuoushinges.com.au/
The stuff bunnings have looks average to me and a quality hinge is what will make the table solid. These guys have them in different thickness.
You can't buy direct but they sell through these guys.
http://www.ovesco.com.au/
So there it is all done! Really happy with the way it come up. Only issue is the hinges I got from Bunnings have a large gap and had to put bigger headed screws in so the table sat level when open.
Getting a better hinge would be a lot easier Pete.Just a thought @17triton is it possible to recess the hinges to reduce your gaps? Bit of mucking around but may be worth it.
nah whip the hinge off, scratch a groove with the circular saw. Put the hinge back. Job done 5 minutes tops!!!Getting a better hinge would be a lot easier Pete.
Hi Triton,just wondering what you made the cupboard out of ? cheers Pilchards.View attachment 48330View attachment 48331View attachment 48332View attachment 48333
New hinges fitted to the table. My neighbour suggested to use Zysa hinges and fitted them for me. They look a lot neater I think.
I used 190 x 19 kd hardwood ( Victorian ash ) and gave it a couple of coats of lime wash to lighten it up and match it a bit more to the Jayco timber finish.Hi Triton,just wondering what you made the cupboard out of ? cheers Pilchards.
Thanks, you have done a top job. How have the hinges held up after some use,is the table still straight or is there some flex in the hinges?I used 190 x 19 kd hardwood ( Victorian ash ) and gave it a couple of coats of lime wash to lighten it up and match it a bit more to the Jayco timber finish.
I sold the van in January mate but the hinges held up well. we didn't use the table a lot and most time was folded back to give us room but definately no issues. Our kids are a bit older as well and knew not to go leaning all over the table as well which helps.Thanks, you have done a top job. How have the hinges held up after some use,is the table still straight or is there some flex in the hinges?
