Hey thomo TV's or LEDs? The 60" are getting cheap
no leds not tv's
Hi ants, not much of a saving going from fluro to led. Just better light when first turned on, fluro's take time to warm up. Some LEDs have better output now as well. Should get better life from LED's as well. Fluros are around 9-10,000hrs ( though some special fluros are now long life), LEDs are typically around 50,000hrs.
Jas
Hey Ants, don't know about the fluro's, your doing well with the power bills though. Wait till little Lucy starts leaving the lights on and having long showers!
I found these today, great if you have relocated your number plate on a rear bar etc...
http://www.ozstock.com.au/8956/FREE-Ozstock-Day-2x-Super-Bright-LED-License-Plate-Light
Sold out.... Bummer.I found these today, great if you have relocated your number plate on a rear bar etc...
YesGuys - have a plan to run some LED strip lighting just under the awning of the basestation to provide some decent outdoor lighting and some bling. The strip lights are 12v - plan is to dial into the current exterior light wiring so when you turn that on - the strip lights will also come on - are all the Jayco LED lights 12v?
Cheers Brad - i am off to work then. Found a good one from Boots33 to remove the light which is handy too.
You Champion - is exactly what i am doing atm - good post and nice pics. What i have been looking for is some trunking to hide/protect the wiring from the LED strip to the existing light.@Lonski mate here you go, see my thread http://www.expandasdownunder.com/threads/awning-strip-lighting-17-56-2.709/ as i used @boots33 knowledge and work a treat for us.
Pace.
Looks good Geoff, nice idea with the USB sockets too, we are off for a couple of weeks for our maiden voyage this Sat and i will see how things go, will likely have a crack at the sockets when i get back.I put some led strip lighting in on the weekend. I fitted an extra Jayco light switch and ran the power to the strip lighting. It is so much better than the original outdoor light. Much whiter and brighter. I have a poptop so probably and bit different than a basestation but same principle.
View attachment 19234 View attachment 19235 View attachment 19236
While I was at it I ran a new 12 volt line to a few 12 volt outlets and USB's. Sick of chargers everywhere. The lights are not seen when in use, you just see a nice reflected glow the reflects up and off the poptop canvas. I also was worried that if I put them up high, the weight of them and poor adhesive on them, they might fall off and drag down the road. Works very well and when I close the poptop the leds are covered by the roof so hopefully water will not be an issue. We had some heavy rain recently and it remained dry as a bone. Family likes it.
Cheers Geoff
