No worries Burnsy.
They're all working well here at my place.
I figure they'll pay for themselves within 2 years.
How much was the impact on yur bill?Hi guys.
This is not really caravan related but thought it's something you all may want to consider.
After converting my Expanda lights over to LED I was really impressed with just how much less power I was saving.
I thought if I can do this to my caravan, is it possible to do this with my house and get the same sort of savings.
So once again I jumped on ebay and had a little look around and see what I found.
I`ve since converted every light in my house to LED and have now seen a significant drop in my power bill.
Click on links below.
Screw in LED light bulbs.
http://www.ebay.com.au/itm/200-240V...ans&hash=item1e717fe594&_uhb=1#ht_5292wt_1006
Bayonet LED light bulbs.
http://www.ebay.com.au/itm/B22-5-5W...t=AU_Lighting_Fans&hash=item43aef01e95&_uhb=1
Small lamp screw in LED light bulbs
http://www.ebay.com.au/itm/E14-Pure...t=AU_Lighting_Fans&hash=item460934022b&_uhb=1
Down Lights LED
http://www.ebay.com.au/itm/10x-Dimm...Fans&hash=item43b4ba713e&_uhb=1#ht_6598wt_882
Fourescent type Lights 120cm
http://www.ebay.com.au/itm/New-LED-...lbs&hash=item43b0abfb08&_uhb=1#ht_2189wt_1170
Hi Holdenman.
Probably late advice but make sure you put a blob of silicon on the lights to help the double sided tape keep hold. All my lights dropped as the heat from the panel made the tape lose its grip and fall down. I bought some good 3M double sided tape from Bunnings and it eventually did the same.
My mate did the same but used silicon and his are still attached. I opted to change my lights back to LED plug in globes to prevent this ever happening. I wasn`t a fan of the tiny little wires that sometimes had bad connections and made the light go out too. Always jiggling them to get the light going I found annoying.
i have ordered some myself i will give it ago too ....why not
