hi
@KBerg Rig , yes I had many a hair pulling moment with fitting mine - from the 1st batch that were offered for sale
1) no instructions
2) no idea on where or how to fit
3) no one at Jayco seemed to know how they fitted
4) Chinese cannot translate millimeters to inches or inches to millimeters
5) crappy screws
6) crappy press studs
7) the whole thing seemed too short overall
8) you have to set the length of the channel to suit your fitting
fixes..............
1) guesstimation and trial and lots of errors
2) guesstimation and trial and lots of errors
3) Useless sods
4) Useless sods
5) replaced (as per
@dagree advice) with quality Stainless Steel ones
6) replaced (as per
7) some modifications on mine
8) lazy shytes for not getting it right 1st time
as there is no instructions, and no-one at Perth Jayco had actually fitted them (at that time), it was guesstimation time
with mine, I fitted the sail track to the edge of the lid
lucky I only put 3 pop rivets in on all sides, as it came off several times to be trimmed & then trimmed again - have since seen it fitted on the INside edge of the lid - mucho betterer I think (looks anyway)
when I could trim it no more - it was then time to realise that the whole lot was 10mm short either side......
looking at it, they had cut the "cord" too short, and sewed the ends there..... shorter than needed - see n#4
I had to "up pick" the sewing on the ends of the "cord", to gain about 7mm
it fitted
it was tight
and the wind would blow and unhook the press studs
soooooooooo
sitting there thinking
I took them to my friends at Hayway Hire & Camping (Gt Northern Hwy Midland) - Blatant plug I know, but they are great people - anyho, they sewed some Velcro onto the edges, and I again removed the press studs, glued the other side of the Velcro on, then re-attached the press studs
that sodding thing "Aint gunna move in ANY wind"
other option was to soak them for a day or two - roll them out on the lawn, attach bricks to one end, and try and stretch the fabric while wet......... couldn't work out how to get tension on the brick less end - so gave that thought away as a bad joke.........
as said
@KBerg Rig time and patience (and I am not known for either) will get it done, one of the things about them being $300.00 cheaper than Holiday Annexes - and you STILL have to fit them yourself.........
