Exterior Hose storage
What size are they? Will they fit standard sullage hoses as per pic I posted earlier of my make do but not really satisfactory adaptor?
The hose is 25mm but with the reinforcing wire the inside diameter works out to be 23 - 24mm... Just makes it a tight fit to get the poly fittings in and out (Well once in they don't come out!!!!)
That's why I'm thinking about the nut and tail/male threaded fittings!
Kebsy56
19
14
St leonards vic
Hi Marv_mart
I use a 45mm square plastic cap but had to file the little lugs down to make it fit. I also have a pin that goes thru the chassis rail and cap. Hope these pictures are some help. sullage 1.JPG sullage 2.JPG sullage 3.JPG I also use the joiner that dagree mentioned and leave it in the section of hose that has the van joiner on. I had to file the barb down on the joiner end that goes in the second section of hose just so it's a firm fit and easy to get in and out. No real pressure on it so should not blow apart.
