Hi. Been trying to catch up with regs for grey water tanks as I think w'll need to fit one but came across this:
Disposal of grey water from caravans
An increasing number of owners have modified their caravans to be self-contained, and manufacturers are now producing self-contained units.
There are now caravan owners who have had their units accredited under the Leave No Trace®(LNT) scheme. These owners also sign a declaration to agree to abide by an 11 point Code of Conduct to do the right thing at all times whilst 'on the road'.
There seems to be some confusion amongst RV tourists as to the correct disposal of 'grey water'. Those who are LNT accredited will be aware, that in clause 9 of the Code of Conduct, it states: All grey and black water MUST be retained in holding tanks or suitable sealable containers at all times, unless permitted to drain grey water onto the ground by a controlling authority.
If you are staying in a rest area, showground, campground, etc where it states that it is restricted to self-contained vehicles and no water is to be drained onto the ground, then all grey water must be collected into a sealable container if the unit is not fitted with a grey water holding tank. THIS GREY WATER IS NOT TO BE PUT ONTO GARDENS OR AROUND TREES IN THAT AREA. It must be disposed of into a dump point, which may mean taking it off site. Please bear in mind that some Councils are now adopting a 'zero tolerance' policy regarding grey water.
If you are permitted to drain the grey water onto the ground and you have a holding tank, then please do this by 'drip feed'. Do not allow the tank to fill and then open the valve to allow all of the waste water to discharge at one time. This only creates an area of soggy soil and can leave an unpleasant smell. Be considerate of others. You would not like to drive onto a site where someone had just discharged all their grey water waste.
If you have collected your grey water into a container, then if allowed, it can be put onto gardens, but it is advisable, if possible, to ask where it is best to dispose of this waste.
I haven't found anything which prohibits the use of portable containers or cassettes specifically for grey water...ebay have several cassette type tanks, similar to the toilet cassette in the van, and I'm wondering if we can carry one of these and make up the plumbing bits to take the grey water directly to a cassette, then carry it away for easy disposal at a dump point??
I know others have designated tanks for grey water fitted and some use home designed ones but I'm after something that is easy to empty and doesn't add weight when its not needed.
I hope I haven't missed a previous post on this topic but I did look..........honest!
