Hi
@Drover , I too have been a little confused at times about the test date. The original 9kg bottle which came with the van is a Manchester and the original test date is clearly visible, so not an issue when getting it refilled at Freddies for $19.95. However, had a reason to swap another bottle for a Swap and Go for $19.74 at Bunnings as a special matching Masters (normally about $24.95)2. Seemed okay until I went to get it refilled at Freddies and I could not see a current test date under all the new paint. At Freddies, I told him of my dilemma that it may be out of test date. Fortunately, he knew where to look and saw some numbers under the paint near the original test date and confirmed it was valid - in fact for another 8 years. But the real interesting part is that when you go to Bunnings (or other places?), they do not even check if the bottle is okay for swap as far as test date is concerned. So I guess that all bottles accepted (whether checked or not) go to the volume refiller and that it is THEIR responsibility to check and certify a recent test date, or else discard or get bottle retested and redated. Somewhere along the line, someone has to certify safe filling/usage, as if a problem occurred, they would carry the can!!
