Electrical Does an inverter require grounding?
devonian
UK
inverter chassis ground, if you have a negative busbar, but run it back to that.
I do have a negative busbar but I thought I was trying to ground the inverter to the chassis ground? Would it not be better to attach the earth cable to the chassis right below the inverter? The negative wire from the inverter already runs to the negative busbar.
19,497
Since you would be using an inverter off grid so earthing to chassis wouldn't do anything as the chassis isnt grounded electrically... any short would make the chassis active. An invertor should be double insulated so any short it shuts down. A van is not grounded .
Reactions: DRW and Brente1982
Fixed
Brente1982
281
183
Epping
Ive watched a few install videos from America and Australia and all inverter frame/chassis earth's run back to the common busbar as well.
