Lol having to take the cap off to use the gas heater is a new one! Do you Lower the legs ? Unlock a hatch? It's just part of the setup if you think it's remotely going to be cold. The other 99.99999 % of the time it keeps the crap out. One of the diesel heaters I looked at recommended same on inlet or exhaust but it was going to be located under the van!
On Gas usage with a gas heater is a non event in a couple of years now we have only had two bottle fills maybe on expandas with less thermal efficiency. But when it's cold I don't try and recreate the tropics inside either!
Both do a wonderful job, self install on the gas is easy with it costing $120 for compliance at the end. It does take a higher amount of commonsense to work out the install correctly which may deter some. But the result can be a much better protected /sealed unit.
Next van I'd happily consider diesel but for MY use I'd have to get past a couple of deterents. I fill the Cruza from xtra hi flow pumps so the heater tank has to take same and I don't want exhaust/inlet sucking from under the van.
Good luck with it either will work really well just gotta work what suits best for you.
