This is ours, it has a generator slide on the other side as well
That looks sweet, how much and can I get one
Great idea @Red1This is ours, it has a generator slide on the other side as well
I have drawer runners in the back of my ute that extend 1200 mm and can carry 227 kgs extended so the runners will carry the weight if the height of the box is adequate,Great idea @Red1
Do you think a portable freezer could work in similar side slide out as you've done with webbe/genie? Need more robust slide. Might be too high though?
Yep, should be fine, the drawer runners will be strong enough, but the height might be an issue, I can only just fit the generator by about 5 mm and I couldn't make the box any higher as the front bed lid wouldn't en(only about 5 mm left to spareGreat idea @Red1
can you put pics with door open as well?This is ours, it has a generator slide on the other side as well
can you upload pics with door open as well please?
Where did you get this beauty and what size panda is it on?This is ours, it has a generator slide on the other side as well
