I dont think there is a whole lot to be gained by connecting the Aux to the car as when the setec receives power thru the aux in it is only capable of trickle charging the batteries. The dc-dc you mentioned is the better option.
G'day Mike. The setec manual says that when using the aux in (ie car alternator) it will float charge the batteries and that trickle charge is still available. So depending on what model setec you have you will either get 10A (ST20) or 15A (ST35) into the battery.
Is your experience different to this? Have you only been able to get a trickle charge into them whilst charging from the car?
Regards,
Paul.
