Hi guys, new to the site although I've been a long time follower so bear with me.
I'm the proud owner of a 2012 16.49.4 with one (so far) small problem. I've already had one Setec ST20 II replaced under warranty just over a month ago after only one trip away. We took the van out for it's second outing last week and the replacement unit blew as well. It supplies power on 240 volts but there is nothing from the 12 volt end.
Having read everything I can find on these units I've got a few questions I was hoping someone can answer:
Tow vehicle is a 2013 Mazda BT50. Obviously this has a variable voltage alternator so I was wondering if the Setecs work with those.
Secondly, the Setec manual recommends a 20 amp fuse between aux power supply (vehicle alternator) and the unit. There doesn't appear to be one fitted, could this be the problem.
Finally, if I have inadvertently left the battery turned on when the unit is also running 240 volts, can this damage the Setec.
I'm a bit worried Jayco may baulk at replacing a second unit under warranty and look to blame the tow vehicle or user stupidity.
Archie
Archie
