Toy Hauler whiplash's work n play
whiplash
34
41
Ah awesome I didn't realize you did a rear bar. Looks like you only needed minimal step down in the tube. Exactly what I'm looking at doing
whiplash
34
41
Rear bar building begins.... Will host a dual wheel carrier :)
whiplash
34
41
Got around to fitting the stone stomper. Few issues but I weeded them out....biggest one was the bracket selection which none of the available options suited the ranger hitch. Due to having a spare hitch I proceeded to cutting and welding the bracket to the hitch. Benefit is I can get it super close to the bar and above the plug. Happy with overall setup. Custom box being made :)
FYI @Stone Stomper...maybe something to look into.
Reactions: cruza driver
skippy
935
793
Butler/Perth WA
That appears to be you trailer wiring for your caravan lights.
I soldered all mine and put heat shrink around the soldered joints.
whiplash
34
41
soo went to Perth and we'll spent a ton of money. Bought Sat setup and was trying to find a nice shelf for the satking and found this nice stainless one from IKEA. Fits snug.
Reactions: Thirstyviv
whiplash
34
41
Oh btw if you want to run cables through the van they run under the shower. Can access the mouse hole by removing the water heater and the power unit under fridge. I put 2x power points from our inverter near batteries to the lounge area fairly easily. also ran hdmi and antenna to our second tv
Reactions: Brian Keith
whiplash
34
41
Mine are on the right hand side of the van. Basically a ton of wire bundled up and under a sheet metal protector.
whiplash
34
41
Positive pressure system installed
whiplash
34
41
Rear bar finished. The spare the guy provided me has the wrong offset....doh!
