Just Browsing Wheel stud pattern on the 2005 jayco expanda's
CamSincs
Cranbourne South
I want to upgrade my 14 inch wheels to 17 inch but I'm not sure what the stud pattern is. Is it a ford or holden stud pattern?
Thanks guy's...
Tricky
467
295
Eltham Victoria
Seems like a big jump in size. You might struggle to get a tyre that fits. Either way the rolling radius should stay similar to ensure you don't run into any fowling issues. The other critical issue is ensure the new tyres are rated for light truck use and can carry the weight.
19,516
14 to 17 more than likely won't fit the wheel arch, check out carbibles.com they have great calculator which will show you sizes.
are they 6 stud already?
if they are, they (Jayco) use the Landcrab stud patten
if they are 5 stud patten, they will be the Ford
Landcrab???
I hardly think that Jayco would use an ancient Morris 1800 wheel.
Additional: They even have their own web site
http://www.landcrab.net/
sorry @PhilD I was on some other forums - and it was a slip of the typing.......... instead of land cruiser
and I forgot that the old Austin1800 was also called a Landcrab.........
