Starcraft What does a 17.58-3 OB weigh?
23chris
73
17
40
penrith
Good evening all I am looking at a new 17,58-3 OB with a fair few mods just after some numbers on what is the weight of there fully loaded van?
ACTraveller
65
64
ACT
The full Specs are in the brochure and are a good guide but you need to watch the tow ball weight on the OB when delivered - see below for one story from Yabbietol.
" The show stopper was the Empty Ball Mass of 263Kg on the trailer compliance plate; this was way in excess of the 175Kg we were advised in July. We own a Pajero and the caravan could not be legally towed in NSW. The dealer was really good they tried relocating the two batteries to under a seat (over the axels) and reweighed the Caravan on the Monday. It then gave an Empty Ball Mass of 243Kg which is still too high as the ATM (about 120Kg higher than in spec) of the caravan was well over 2.5t (the Pajero needs an Empty ball mass of 180Kg over 2.5t). We also visited a local engineering firm about getting the Pajero towing weights upgraded, but this is expensive and still 240Kg is a lot of weight on the tows rear axel.
Since then we have had to do a lot of thinking as the Caravan was really nice and what we wanted, but the heavy weight on the tow ball worried us. We checked with a few Jayco dealers and found that a typical Empty Tow Ball mass for the Outback version was around 230Kg to 257Kg nowhere near 175Kg. It looks like the Outback version has a serious design flaw.
We also got some good help from @ACTraveller who has the touring version of the same van built around the same time. Their Empty Ball Mass was 166Kg which is much more realistic. It appears the weights of the touring version are fine and the Outback version has the problem. This Outback problem may be due to the extra 300mm length and heavier chassis plus the JTEC suspension shifting the Caravan centre of gravity further back than the touring suspension.
We are very pleased with the dealers efforts to resolve the problem and they are giving us a full refund of our deposit. So we have no complaint about dealer service, but we have an issue with the engineers in the Jayco factory who got the weight distribution so wrong. We are now starting with a clean slate. Most likely we buy off the lot to ensure the empty tow ball mass and ATM is reasonable."
23chris
73
17
40
penrith
Thanks for the feed back sounds like some bad news for yab,
What was in the show stopper deal?
Is this a one off issue all is there others with the same problem?
Why weights do other 17.58-3 OB owners weights?
The ext draw bar should increce ball weight but by how much?
3,031
3,401
We are around 2650kg when all loaded up. That's water and gas, clothes for 4 (sensible), food, gas heater, carpet, underneath protection and a box on the drawbar with gen and weber. I load bottled water in the tail and have the spare on the rear bar. Ball wieght is around 190kg.
2,651
3,817
I agree there all over the place with there weights my 1756-2 outback is well over on the ball for the prado weight of van ok but ball no good
