what do you know about sinks?
Triton
96
19
Moama, NSW
Had to pull sink out to tighten mains tap up. ..... but of a mission. See if I can get it back in a again!
Triton
96
19
Moama, NSW
Mission accomplished. Bit tricky to get to nut that holds the tap tight in place. Then had to work by feel to get the clips back in place at rear of sink.
3,060
2,345
i almost resorted to pulling the sink out on ours to the the same thing, thought better of it after removing first clip and that was one I could see.
managed to get it tight enough (by feel) with open ended spanner, then had Jayco do it at a service
4,298
Loctite the bloody thing, ours came loose every day, great fun pulling the draws out and trying to tighten the damn thing. Eventually I crawled half under the sink to discover it only has half the washer (compared with similar taps at home), anyway Loctite will be used on the thread into the fitting and the nut, maybe I just drive too fast over rough roads?
