18' Series Water Pressure
15Stanners
13
Bailey15
Hi Guys, hoping someone might be able to help me.
I have a Jayco Expanda Outback
Appear to be having water pressure issues. When drawing water from the tanks using the pump pressure is great, however when hooked up to mains the pressure is not so great.
Anyone have the same issue and if so what did you do to overcome this?
Cheers in Advance
Paul
19,508
Welcome to the world of Jayco, what you are finding is very,very common and has been the source of many threads on the subject, a search will bring up many with great detail but the quick version is if you look at the mains inlet line you will find a large fitting of brass and plastic, this is the PRV/PLV, pressure reduction/limiting valve which is supposed to limit your water pressure, this often causes problems with pressure their are 3 ways to fix it......
1...........Remove and replace with another, available from Bunnings as they are just normal household PRV/PLV's but check the size of your line connectors to make sure they match..........check the flow thru of the unit before you bin it though, reverse flush as it does have a filter inside.....well most do....
2...........Remove, dismantle and stretch the spring inside while this works it is not always reliable and the spring may reform.
3...........Remove dismantle, throw away the loose bits and put back together and refit..........you still get a pressure restriction but the flow will be normal, I have used this method on 2 vans for a number of years without any problems, haven't found any places that have any pressure to worry about, the Guest fittngs and lines on a van are good for 150psi if fitted correctly and the HWS has it's own valve......
Always run the mains tap then flush your hose before you connect up to van, thusly ensuring you won't be pumping a bugs nest into your van when you turn the tap on and clogging everything up, coil your hose up and connect the ends together to keep out bugs and dirt when not in use.
It is a good idea to get some spare John Guest fittings, a spare NRV, joiner and elbow can come in handy along with a small length of pipe, colour doesn't matter as they are all the same specs............
19,508
, That fitting in the the mains connector is usually a NRV valve, stops backflow from line when not connected to mains and using the water pump, if when using the water pump and you notice water coming from the mains connector the NRV in the connector has popped it's O ring.........
That fitting in the link would be a bit of a worry if the details are correct, reducing mains supply pressure to 120 psi when the van fittings are rated at 120 psi (820kpa) a PLV of around 500kpa (72psi) would be more suited.
Reactions: Marv_mart
15Stanners
13
Bailey15
Thanks for all the advice. I disconnected the PRV last night and will heading down to get a replacement and see how we go.
Thanks Again
19,508
Check the PLV isn't just clogged and check the flow before you shell out for a new one or you may find it was something else causing the problem.
