Interior Truma Aventa Air Con
GlampinCdub
14
Hey all,
Have a quick question, has anyone had issues with the Truma Aventa air conditioner on heat?
I think the heater core must be blocked as the heater won't actually heat the fans are on but no body is home.
I thought about pulling it apart myself but not sure if the heater core is accessible from inside the van once you take the face plate off, or if it is sitting on the roof.
Worst case i would take it to someone to get repaired but i wouldn't know who or where yet as i just moved to the area.
7,404
Hey all,
These a/c units will not heat if the ambient temperature drops to around 4 degrees or less, which is why a lot of members have installed diesel (or gas) heaters.
19,499
They are reverse cycle so no heater core as such, just instead of cool air blowing inside and heat outside its the other way around, they really only work between 3-4 deg and about 35-38 and thats roof mounted the cupboard jobs are hopeless........ If there is no heat and its a normal sort of cold day you could find it won't work on cool either, repairs can be expensive.... I would follow up vehicle AC repairers as often a dealer will just farm the job out anyway.... sunshine coast has a couple of good repairers, can't think of names off hand atm. Read the manual fully.
Reactions: mfexpanda
GlampinCdub
14
Cheers, yeah i have installed a diesel heater myself. The heater though wont even work if it is say 14 degrees it just blows cool air haha.
Reactions: chartrock
