Journey The Journey is Home.
19,502
Couldn't be stuffed just use a small gas bottle then I can move the barbie around.................bayonet is a pain.
roika11
16
6
Finished a couple more mods yesterday. Fitted shelves to the wardrobe and managed to hinge the top and bottom fixed panels to allow better access to the top and bottom shelf
View attachment 34379 View attachment 34380 View attachment 34381
Also managed to install my 1200W modified sine wave inverter under the seat and a black power point and switch as I don't want to leave it on when not in use. I used an 80 amp circuit breaker as a switch and inserted an LED into the power point to show when it is on.
View attachment 34382 View attachment 34383 You can just see the LED in the top right corner of the GPO.
It will mainly be used for our coffee and frother. :D
Thanks Chartrock, Very useful. Just 2 questions: Is the 80amp circuit breaker on the DC or AC side and did you connect the DC direct on to the battery terminals? Cheers Roika11
7,406
80 amps is on the dc side, if I pulled anything approaching 80 amps on the ac side I think my dc cables would melt. Yes the battery is almost alongside the inverter and is connected direct to the battery via the circuit breaker. Hope this helps @roika11
