Exterior Spare Relocation
vasco pyjama
45
No worries will get them to you when i knock off sunday . Should have documented them when i done the job but it was all done on the go.
vasco pyjama
45
Here are dimensions for spare wheel carrier for 2014 17.56 outback Expanda as requested by a few people hope they are easy to understand and also some dimensions may vary on different vans so measure twice cut once
Cheers Vasco
  • SPARE CARRIER.PDF
createit
41
62
Well I acquired a landcruiser spare wheel winder and then called in a favour from a friend and we spent last Sunday in the workshop. We decided to build a cradle and use the winder to raise and lower the spare. Here are the results:
createit
41
62
The extra pics. After a few tests this weekend I can raise and lower the cradle with the tyre in it without using the winch. Makes for a quick tyre change.
Reactions: hamish22
MDS69
728
794
Hi @vasco pyjama what did you use for the winder handle. I found the winch for $77.00 on ebay but they are $99.00 with handle. Does the Jayco supplied item for the jack work. I haven't even looked at the handle to determine. I am just at work browsing and thought I would ask.
vasco pyjama
45
Hi MDS69
mate i just went to the local Toyota dealer and got an extendable jack handle and cut the hook off the end and ground it down to suit the winder.
Cheers Vasco
Reactions: MDS69
19,504
I just used a piece of reo rod , a bit of flat welded on end for winch and an old socket for a handle to fit.
