Electrical SETECT ST-III and Battery Capacity
I am sorry to differ, but be assured that the rated output on a panel is possible and is indeed easily exceeded.
I have a 40W panel rated at a maximum of 2.23A which can regularly output over 2.5A.
Panels are rated at a solar insolence of 1,000W per sq m. In Australia on very clear days solar insolence can easily exceed this figure and if this happens in the morning or in windy conditions which will keep the panel cool, current figures will exceed the panel specifications.
So, please change the word impossible to something which is actually accurate.
Failure to achieve the rated output is regularly caused by recovering batteries that are fully charged, panels not optimally aligned to the sun, or panels supplied by a dodgy supplier.
If I was buying panels, on delivery, I would set them up optimally in good sunshine ensuring they were not hot and measure the S/C current. If it did not provide the rated Isc, they would be returned as faulty.
take care
1,814
Am I reading it right that the MPPT controller you linked to only has a boost voltage of 14.4V? Or does it let you select AGM to get to 14.7V?
Hi @Fallen, it does not have a setting for AGM per sec, and as I wanted higher voltage than 14.4 volts for "sealed", I spoke to technical guy at Seller, and so selected "Flooded" which has a max charge rate (Boost) of 14.6 volts. Other specs such as Float (13.8 volts) , over voltage protection (16.5v), max charge limit (15.0v), over voltage re-connection (15.0v), and Boost restart 12.6v) are the same for all other type except GEL which has a lower Boost (max charge voltage) of 14.2 volts.
Unless they are fitted to a tracker it's all academic anyway as they will never be in optimum position.
it is not difficult to set up a portable panel in an optimal position for an hour or so.
I usually need to go do something regularly enough that I can walk past the panel and give it a nudge often enough to keep it reasonably close to an optimal position.
I just want to dispel the myth that it is IMPOSSIBLE to get the rated output from ALL solar panels.
I very much doubt that panels supplied to solar farms do not meet or exceed specification.
Relying on this myth leads many inexperienced people to accept poor solar performance and to not attempt to investigate or understand what is causing it. The solution inevitably is just to go buy some more panels.
I suspect that this myth also underlies the reason for some dealers to quote unrealistic figures for solar panels knowing that:
1: A lot of buyers do not have the ability or understanding to evaluate the panel.
2: Buyers will generally accept an inferior product claiming that all panels are overrated anyway.
3: Those that are unhappy will more than likely whinge on social media about the *&^&*^*& panel but seldom sort it out with the supplier.
I was a retailer in electronics for long enough to understand how customers think and how marketing works.
take care
1,814
Hi @Boots in Action, have just ordered an MPPT controller to replace the TPS 1230 in the van.
I have chosen the same one as you have as it seems to be value for the price and I don't see that blue tooth or other new fangled stuff is a
necessary requirement.
Will let you know how I get on.
@Johnanbev , I have been more than satisfied and it does all I need. You will have to connect the LOAD through the controller to get all the data. If you have any problems, let me know and I should be able to assist. Maybe have a look back to one of my posts on how that was done. @Grandpa Gunna has been successful at the modification I have on that post also.
Reactions: Johnanbev
1,814
take care
Okay Mike @mikerezny , I have to bow to that comment and have changed the wording to "very rarely"- perhaps about as likely as me having perfect weather every time I am off grid.
Nevertheless, what you say does need to be considered and the makers of good controllers take this into account. The following is taken from the instruction booklet for my MPPT controller:
"This product has limited input power function, and in theory, no matter how much power of solar panel input, the controller will limit the input power
to under the rated power, but attention is drawn to the following.
As the Open Circuit Voltage of solar panel increases with decreasing temperatures, please ensure that the open circuit voltage will not exceed 100 volts as this will trigger protection circuits to prevent damage to controller."
And other place under features quotes as follows:
"PV array limited power input function to ensure controller does not overload operation under any conditions".
As the connection of my 3 panels only reaches approx 56.0 volts under ideal conditions, I do not believe i have anything to worry about.
19,522
take care
Yep I do the same but my roof jobs take what comes......your points apply equally to van, car and many other purchases.
and we all know about salesmen............................. I have found this to explain things pretty well https://www.gorv.com.au/10-rv-solar-myths/
1,814
Hey Boots. The 30A reg you mentioned has a max panel output of 400w at 12v, how would you achieve the rated 30A with 400w of panels ???
More info for you @Crusty181. A max CONTROLLER output of advertised 30 AMPS at only 12 volts would amount to 360 watts . At a CHARGING voltage of 14.0 volts amps would be around 25 amps which is what I have achieved. As voltage rises because of less load, current would increase. However, the efficiency of a good MPPT controller is able to convert any excess voltage into more current within the limits of the design of the unit.
Note also, that all wattage produced , besides charging battery (if needed), also provides power for any accessories on at the time such as fans, radio, USB charging and any light that was necessary. And who knows if the 30 amp max could be achieved or surpassed. It is only a tested rating at the manufacturing stage.
Reactions: Crusty181
1,814
take care
@mikerezny , amended as requested with the relevant proviso though, See earlier post.
Reactions: mikerezny
1,814
More info for you @Fallen . Yes AGMs do like around 14.7 volts (max) to achieve a full charge. Attached is copy of Battery type selection on the MPPT controller I have. So I selected FLD (Flooded type) to get voltage up closer to 14.7 volts. Remember, this setting is for battery temperature of 25C and the temp sensor will adjust this figure slightly as necessary - upwards when below 25C and slightly lower when battery temp is above 25C regardless of ambient temperature. Hence the importance of a sensor ON battery, not at controller itself. Hope this satisfies your query.
Reactions: Fallen
Macca_75
680
596
SE Suburbs, Vic.
Back to OP - I noticed my Setec never fully charged the batteries. Doesn't really matter - I replaced the crap regulator with a Victron MPPT and set the Victron to match my battery. Since I never use a cover my batteries are charged to full almost every day (exception might be when free camping for a few overcast days - but it catches up either when we travel next, weather improves or we hit a powered site so the solar only needs to "top up" the batteries and not provide all of the charge.
Hope this helps.
1,814
Hi @navara1999 , if you go back to the beginning of this thread, you will see the same question asked by @Rayden. A 120ah battery will take slightly longer to charge than the previous one which was probably a 100ah capacity, that is the only difference. The major change will be if you now have an AGM battery instead of a GEL type. If you have a SETEC ST20 Series II or III, (which charges at max 10 amps) it will not bring out the higher capacity of the AGM as Setec charges to 14.05 volts only, barely enough to fully charge a GEL type battery and far short of optimum of 14.7 volts for AGM types. There is plenty of info provided earlier on this thread.
Now I believe @Macca_75 has thrown out his lead acid type batteries and is now using LITHIUM which have an entirely different charging algorithm which the Setec cannot achieve, and also his Victron solar controller (up market type) has settings to match the proper charging specifications LITHIUM batteries require.
Also note his last post regarding adjustments on drifter panel if you have one.
If you are sticking to the AGM type, the Setec won't really do the job, but a "smart" multi-stage battery charger will. And a good genuine MPPT solar controller will give better performance that the PWM type which I assume you have.
Macca_75
680
596
SE Suburbs, Vic.
Nah - I'm still (now) on the original Jayco Ritar (was over weight on our trip around Aus so had to drop the extra battery out). I leave the Setec to do the bulk of the charge (when plugged in) and Solar (using the Victron MPPT) will top it up to the exact voltages recommended by the manufacturer (you can set the Victron gear for Bulk, absorption and float to whatever you like - if you also add a battery sense and create a network between the MPPT controller and battery sense like I have done the voltage readings (and temperature) are taken at the battery and so can adjust for any losses in the cable as well as allow for the temperature (higher or lower) or the battery.
1,814
Sorry @Macca_75, I thought you had changed to Lithium - must be someone else on this forum.
I too only use the Setec to charge my single 120ah AGM battery and to supply a constant power supply when on grid at caravan parks etc, and battery has lasted over 8 years. When off grid, all is done by my series connected solar panels and accurately charged by my much cheaper MPPT controller. Like your Vitron, it also has the facilities to adjust any settings for bulk (boost), absorption and float according to "user preferences" or manufacturer's recommendations. The controller has "on screen" readouts and button adjustments for settings (no separate screen or blue tooth control needed) for all of the above and my battery is within 300mm of controller, so I have no need to create a network. Also, the unit comes with a temperature sensor which connects to controller and enables me to actually place the sensor on the battery, (and not use the controller temperature auto setting at the controller!) and automatically adjusts the charging voltage up or down according to battery temperature. Does the same things at a much cheaper price as I was not willing to pay for a more expensive sophisticated unit .
Macca_75
680
596
SE Suburbs, Vic.
Sorry @Macca_75, I too only use the Setec to charge my single 120ah AGM battery and to supply a constant power supply when on grid at caravan parks etc, and battery has lasted over 8 years. When off grid, all is done by my series connected solar panels and accurately charged by my much cheaper MPPT controller. Like your Vitron, it also has the facilities to adjust any settings for bulk (boost), absorption and float according to "user preferences" or manufacturer's recommendations. The controller has "on screen" readouts and button adjustments for settings (no separate screen or blue tooth control needed) for all of the above and my battery is within 300mm of controller, so I have no need to create a network. Also, the unit comes with a temperature sensor which connects to controller and enables me to actually place the sensor on the battery, (and not use the controller temperature auto setting at the controller!) and automatically adjusts the charging voltage up or down according to battery temperature. Does the same things at a much cheaper price as I was not willing to pay for a more expensive sophisticated unit .
If it does the same thing - perfect.
My original 120ah agm is almost 12 years old now, and still going strong. All but the last 12mths on the Setec, be struggling to get a better result than that I expect
