repair advise roof hatch
thomo67
anyone had to repair tyhis before
the pop up roof catch ?
as per photo
whats behind this pannel ?
BJM
485
549
Yamba
as per photo
I can not remember if it has a plate bonded behind internally.However the outer fibreglass panel that is fractured is bonded to the styreen foam then bonded to the interior ply.Not a small job ,however a good fibreglass boat repairer would be able to do it .not a simple job for diy
thomo67
thanks for your reply
19,497
A long time ago someone showed us their repair .................. I believe they bogged the hole with nails or similar then an alloy plate was glued and screwed over it with the catch screwed to it.... have seen many with an alloy plate behind those catches so not uncommon.
Middo
137
140
75
Did our when the screws broke. Just glued an aluminium plate over it and shifted the screws slightly.
