Hi all,
We have a 20.64 expanda, and recently the strip light above the sink has started turning on by its self. Our van has the programmable sphere lighting system. Once the light has decided it wants to come on, it cannot be turned off using either the switch that it was programmed with, or the off switch on that switch panel. The only way to shut it off is to use the receiver button that belongs to it which is mounted in the pantry. I then have to reprogram that particular light. I have had to do this several times in the past couple of months, and throughout this time the van has been parked in the shed.
Any thoughts on what could be doing this?? None of the other lights have done this.
David
David
