With regards to the first point, I can recall reading the Redarc site that you can simply use a longer lead up to 5 metres. I am trying to find the exact location of this to link to.
BJ
Edit - found it, it is in the FAQ's of the user manual for it.
Can the remote head cable be extended?
Yes, the remote head cable is a standard RJ45 network cable and can be replaced by an off the shelf cable up to 5m in length.
Ok I will let the sparkies know about the longer network cable. Thanks @Bmhdg76
Thanks for clarify that BJThe redarc is adjustable, Skippy was just referring to the boost settings that the P3 has.
BJ.
You don't really need the boost on the 16 expandas but once you go up past the 18 the boost function is really handy for pulling up a lot quicker when fully loaded @Holden_manOk well that's ok, happy to be adjustable, I haven't used the boost settings on the P3....
I find the boost great in traffic and once out on the open road it's really handy if you have to pull up quick for animals too.
Basically I was hoping that the Redarc unit would have the same boost option as the P3 but apparently it doesn't have this option which is fine if your towing a camper trailer or anything under a 16 footer.
Anything over 16 I would defiantly recommend the P3 but for anything under I am sure the the Tow Prow would be a great unit out of the way from the knees unlike the P3 at this stage, with a bit of luck they will update their unit with a remote head like the Tow Prow as well.
