Electrical Rear Tail lights
Jaybird
192
72
Gippsland Lakes
Jayco discovery with the round LED tail lights. I have just noticed one of the lights has some water in it so I removed the 2 screws to remove the lens but can't get it off. Is the LED part of this lens and if so how do I remove it. I was able to lever it enough to get most of the water out but that dosen't fix the problem. Thanks.
19,516
If I remember water inside is common, the light does remove from the shroud but they don't come apart to allow you access to the led's, they are a sealed unit even the ones with removable led's............ a small hole drilled lets the water escape and a liberal smothering of silastic on the back and sides might stop ingress.
