No Options Apply Pump
19,510
No pic on your post ....... But if the normal 3 way tap, look closely and you should see some arrow heads, line them up so the tank you want lines up with the pump line and your good to go......
19,510
Bunnings has some garden irrigation taps, 2 for about $6 they work fine as a replacement for the 3 way tap when it wears and sucks air.
One of these and a T piece and job done. Taps off 2 ends of T and other to pump....Depending on tank you want, turn one off and the other on.....did it on my old 14.44 worked a treat.
https://www.bunnings.com.au/pope-13...VgxiPCh2ODwlhEAYYASABEgIHLfD_BwE&gclsrc=aw.ds
https://www.bunnings.com.au/pope-13...VlROPCh1sVAA7EAQYASABEgIyVPD_BwE&gclsrc=aw.ds
Reactions: Jack Lucy & Josh
millers
282
246
Second that modification. have two on each tank. One each for electric and hand pump. All combinations of water supply available and taps located near tank.
