Can anyone see any issues with changing over the clear plastic water hose pipe that goes from water tank outlet to water pump inlet over to the 12mm semi-rigid black piping, the same that goes from the water pump outlet to all the taps. The clear looks to be about 15mm, not sure if going the smaller diameter will effect the ability of the pump to suck it up.
