17' Series No Hot Water
Hoffy
66
76
Gold Coast, Queensland
Hi Fellow Jayco Lovers, We just took our 17.56.2 expander off road and when we put the hot water system on and turned the tap to hot, no water was coming out? It was fine if you put the tap on cold but as soon as you swung it around to the hot, nothing? Any ideas with whats the problem here??
Many thanks,
19,502
Underneath your van is a tap should look like the one on your house HWS in some cases, anyway turn this on and you should get water..... Always run water thru your HWS till it stops spitting before you turn HWS on, then you know the tank is full and won't burn out elements or waste gas.
Hoffy
66
76
Thanks Drover, dopey husband had turned it off when he changed the water pump. All fixed now.
Reactions: KECL
