Apologies if I have posted this in the wrong section.
We have pulled up for the night and was looking forward to a nice warm shower but I am getting no flow at all from my hot water. I turned the gas on, as we are off the grid (got bogged turning around as you do so I unbogged the car and decided that here is as good as any place to stay for the night, but that is not the problem!) and it all started perfectly and l left it 20 minutes and then tried the hot water but I am getting no water flow at all when on the hot side of the tap. The cold side is working perfectly but if you turn the tap around to the hot side the water stops flowing. I opened the hot water hatch and gave the overflow a pull and got about a cupful of hot water out but then nothing.
It was working perfectly on our last trip and the only thing done since then is we got a diesel heater put in which we routed through the tunnel behind the hot water. I've had a bit of a look but I can't see any obvious wire problems and was just wondering what controls the flow through the hot water system?
Anyway I will have a decent look underneath tomorrow once I shuffle the van back onto the tar:doh:
