New ute
mfexpanda
4,246
5,284
Brookfield, Vic
All dressed up and nowhere to go.
Bloody coved-19
mfexpanda
4,246
5,284
Brookfield, Vic
and more cabin fever ----
provent catch can installed
CEL-FI GO fitted
slimline light bar under roof rack
extra compressor switch fitted inside cabin 1 in tub 1 in cab
2 red anderson plugs fitted for solar input
Grunt gas struts fitted on tailgate for easy open/close
gas struts fitted to bonnet .
K&N filter installed .
Reactions: davemc and Drover
CEL-FI GO fitted
You can use none of that now so I suspect that would suggest you're possibly about to be Covid non-compliant. Under Dictator Dans new 4th Reich laws, the local 7-Eleven or Donut Shop owner can arrest you .... have you seen Tom Cruise in Minority Report cause that's kinda how it works. Best to get yourself up to speed before Mr Donut come knocking on your door, before you commit the crime. The future evidence against you, of you maybe doing something wrong, is overwhelming
mfexpanda
4,246
5,284
Brookfield, Vic
I think you may be right .....
We need to down grade from defcon 4
mfexpanda
4,246
5,284
Brookfield, Vic
Had a auto trans cooler fitted at wholesale automatics .
39deg outside going up all the hills to Ballarat .
Trans avg 87deg going up those long hills 72 deg on the flats .
64-72 deg coming home . I’m happy
19,506
So long as the engine temp stayed around the 100 or so all should be good, I like the tranny temp around the mid to high 80's, if it has a manual fan fitted let the temp climb to about 80 then flick it on.............. the car should be a lot happier for sure.
Reactions: mfexpanda
mfexpanda
4,246
5,284
Brookfield, Vic
never owned an auto before . no manual fan on the cooler either.
off to Lakes Entrance wed night so we'll see how it goes on a longer trip.
