Exterior New door at Last
Seanm5253
65
106
56
Hillarys Perth
Hi Everyone
After a 5 week wait for the door to be made i finally have a door on the van!
Thankfully i measured correctly and was installed in a couple of hours, now I'm after some advice on what everyone does for privacy as we had a Jayco factory door before that had half a curtain but this being a premium camec door I cant see a way of installing a curtain / blind.
Any photos or ideas anyone????
Reactions: Rockape and dagree
7,410
G'day @Seanm5253, on both my old Expanda and current Journey, the curtain is mounted on the inside of the wire door. I can't get to the van tonight to see how it is mounted but simple small nut and bolt through the frame of the wire door holding the stretch wire at the top and bottom threaded through a curtain is all that's required.DSCN3845.JPG DSC_8703 1.jpg
A bit harder to see in the second pic but it shows it inside.
Seanm5253
65
106
56
Hillarys Perth
G'day @Seanm5253, on both my old Expanda and current Journey, the curtain is mounted on the inside of the wire door. I can't get to the van tonight to see how it is mounted but simple small nut and bolt through the frame of the wire door holding the stretch wire at the top and bottom threaded through a curtain is all that's required.View attachment 41548 View attachment 41549
Hi Chatrock
Thats exactly what our old door had, couldn't remember how it was fixed though
I was hoping not having to drill through the new door but might be the only way me thinks!
Reactions: chartrock
OOPs... I was under the impression that you wanted to fit it to the main/solid door. Ours is fitted the same as @chartrock and is held on with curtain wire. small hooks and self tapping screws.
Pictures are worth more than words ;)
Seanm5253
65
106
56
Hillarys Perth
View attachment 41550 View attachment 41551
No.... The frame is about 10-12mm so guessing screws would be no more than 9mm long.
That makes sense, that was my concern
Now I have a plan of attack
Cheers for the help
