20' Series Mould and water Stain Removal
15Stanners
13
Bailey15
chasing some advice or guidance on what i can do remove these water stains and the mold.
I have tried spraying with vinegar and also tried the brand 303 "Mold and mildew cleaner and blocker"
19,502
That should have killed the mould but the stains won't go away they may fade in time ........... You can mix up a strong brew of tea in a bucket, strain the leaves out then spray the brew onto the canvas, inside and out, a good soaking and it will give a khaki type colour, may need a couple of goes, you can use coffee instead, even heard of using a water based wood stain ..............
Once its all dry then grab a big bottle of oilskin coat waterproofing liquid, not the spray can rubbish, spray it over the canvas, if you give it a good soak with that yearly it will keep the moisture out, just never fold away when damp, well open up to dry soonest if you do ... I also rub some wax stick over the stitching to keep it sealed....... If the canvas starts to fall apart before it goes too far find a Canvas Shop a place that makes tarps and things, they can make you a new bed end far better and cheaper than a dealer and you can get better screen material as well, just remove it and it will be heaps cheaper.
