Hi All, I chased up Brash Imports about an update for my in car satnav from them as it had been 18 months since I updated it.
I got this back from them
Use this link these maps came out only a month ago
https://www.dropbox.com/s/bpabefd28epz4ae/2016.zip?dl=0
To update the existing card is relatively easy
1) Make a back up of your existing card by copying the entire card to the computer.
2) Go into the IGO folder
Go into the Content folder
3) Delete the following folders
Map
Poi
Speedcam
4) Extract the files from the download. When you extract the files they should be in their relevant folders. If not then use Winrar instead of Winzip.
5) Copy these folders back onto to the SD card
When you start the unit again it may seem to freeze when it loads the first time and may be slow for about the first 1 – 2 minutes.. this is normal
and that is it!
Map
Poi
Speedcam
and that is it!
