Ok so the main table in our 14.44 seams really low and i struggle to slide under it.
Question, can the table be lifted further up the wall and use the mounting strait to the wall as it currently has?
I would like to lift it up about 40mm at least. The leg will be sorted by a spacer out of timber.
I am just not sure if there is some sort of structural support in the wall where it is or simply just lift up and bolt up???
Advice
Advice
