Exterior How to fit pole, fishing rod holder to Aframe advice.
Jeremy Johnson
79
131
North Queensland
Hi, I am looking fitting a PVC 100mm pole/rod holder to the drawbar. Does anyone have any good ideas on how to secure.
Have been told not to screw / drill through top of draw bar for structural reasons.
We have a stone stomper so rocks / debris should not be an issue.
Thanks in advance.
Dan-14.44
23
Geelong
Thanks in advance.
You don't drill through the frame because it will damage the galvanising. A small 3-4mm hole in your frame won't effect it's strength but it will be a spot for corrosion to start.
Reactions: Jeremy Johnson
I used the brackets that came with the tube. I had to recess the bolt heads so the tube didn't sit on them, probably would of been ok though.
Reactions: JaycoQ and Drover
