Hey,
I have a Heron 2.2 fitted and when cooling after about 5 minutes the condenser fan stops working and so does the cold air. I am told that the thermostat and resistor is what controls the fan from working however
after some investigation my Heron 2.2 doesn't have a resistor in place and it appears that the thermostat has been bypassed. At present with the thermostat bypassed the fan runs flat out but then stops after a few minutes and moments later the compressor trips the over load and no more cold air...
I am open to any suggestions if you have any. Cheers
