Hi all I am new to tis caravanning stuff so I will no doubt be asking many more questions in the coming months now for this question.
Does the H/W system fill when you are in a caravan park and have a hose connected to the van (and turned on of course) or does it only fill from the water tanks under the van via the 12v pump? I have done a search and found heaps of great info but I can’t find the answer to this question.
Also do these units have some sort of float switch for maintaining water level? as you use the hot water I am assuming that it is replenished by cold water whether it be from mains or 12v pump via some sort of level control using a float switch.
