every van I have had I had rewired the fridge to an Anderson plug and by passed the 7 or 12pin. They have generally worked better and 9 outta 10 plug related issues I have seen or helped fix on vans it's been because the high current draw item has burnt the plug and then the wiring. But as the. Starcraft had slighty heavier wiring and I split it at the plug over two pins each I thought it might be okay and the fridge has performed okay on 12v as well.
This last trip I put my fingers on the pins after I withdrew the plug and I couldn't touch the pins they were that hot! So Iam going back to an Anderson and heavier wire direct to fridge. Yep it's another connection to do but I just don't want hassles somewhere in the road.
