Exterior Gas fitting
Ross Falcke
31
14
melbourne
OK, so I've gone out and bought a box to mount on the A Frame with the gas bottle inside. Got vents etc. What I would like to know is the regulator the same as a standard regulator on a flexible BBQ hose?
My issue is the hard copper pipe on the regulator makes it impossible to fit it all in the box.
Otherwise I have a new aluminum box for sale.
Roscoe
Reactions: Delano
You can get flexible lines to replace the hard copper lines. Whilst the flow rate might different, the pressure should be the same so should be able to use a standard line
Reactions: Delano
I had a mate (gas fitter) come and inspect mine before I was about to cut the main pipe and feed it into the box
he suggested unscrewing the regulator and feeding the pipe into the box - then re-fitting the regulator
like in the pic below from mine.....................
Reactions: Delano and dagree
19,516
They are supposed to have a vent in the floor and have a barrier so other stuff in box isn't packed around them or the reg.
the legalities are - it needs to be separated from anything and everything, and that nothing can damage them - like something falling on them, moving and damaging the pipe etc
minimum of 3 vents I think it is
I have
1 low (Gas Bottle side)
1 low (Gas Bottle rear)
1 high (opposite side of box)
also a drain underneath
the venting is so you dont have a BooBoo with leaking gas
They do have vents and barriers now @Drover ... That pic was taken during the installation phase!
I have pretty much the same as @bigcol
2 x vents on both ends. (high and low)
1 x vent per bottle on rear (low)
1 x vent/drain on floor per bottle
Reactions: bigcol and Drover
