Fridge not working
19,522
Or it could be the power point, the switch went dodgy on my power point the other day and for some reason before I pulled the whole place apart I tested the socket and no power, so moved plug and all working again..................sometimes the Gods smile upon you.
Found the actual switch had a broken plastic bit.
Reactions: bigcol and dagree
Dez
4
@chartrock Thanks buddy. Looks like you cracked the code on this one.. I threw the double adaptor as far away from the caravan as possible, and WELLAH... it works like a gem! One last question though. When caravan is plugged into 240v, do I need to have the battery switch on or off to charge the battery. Or does it charge in both positions....?? :minion_tongue:
vindiboy
New York
the refrigerator condenser fan and compressor, located near the floor on the back of most refrigerators, come on when the thermostat calls for more cooling. If you don’t hear the compressor running after the door has been left open for a while, it could mean the condenser fan is stuck or worn out or that the relay or compressor is bad.
refrigerator reviews
