I'm keen to fit a rear view camera to our Expanda 12. I've had a look at a few forums and came across numerous posts with some very clever mods but not specifically for my van model. My preference is for a hard wired system, not a wireless one as I haven't read too many good reviews about the quality of signal. I bought a cheap system (camera and monitor) off ebay and have been considering fitting options ever since. I wanted to locate the camera at the rear top centre, drill a hole to feed video and power cables through and wire up internally. I could not find an easy access to 12VDC and routing of the video cable, either internal or external, to under the van was also problematic. One mod I saw online was a camera mounted on a post and secured to the rear bumper. Thought that was a clever idea but the bed lid on my van drops down at the rear. Thinking about a design a bit more, I thought I could still mount the post on a plate welded onto the bumper but hinge it so I can raise or lower it. So I put together a simple (read ugly) concept demonstrator shown in the following photos.
When raised, the base will butt up against a 90 deg bracket and I'll put a bolt through to secure. Cables will run down centre of pipe; I'll tap into the 12VDC wires for the number plate light. Power from this light will let me switch the camera on or off by turning on the car lights. The video cable will be zip-tied along the chassis/wiring loom. Hopefully readers haven't dozed off by now (a bit long winded I know).
I'd appreciate any comments on possible problems the 'design' may have that I have overlooked or any other possible install solutions. Thanks in advance.
