The 18.58.2 is the largest of the expander pop top range having a separate shower toilet vanity
Being a pop top with an extended draw bar means this van is a pleasure to tow, with a few added extras to make life more comfortable.
Extras:
Diesel heater - (2.2kw from Diesel Heat Tasmania) with 10lt removable fuel tank for easy refilling
56 Lt dedicated drinking water tank - has its own separate fill point, pump and filter, through to a separate tap at the sink
Portable grey water tote - housed in a second under chassis spare wheel carrier
Extended draw bar
Additional 100 amp battery - makes a total of 2 batteries
Upgraded to a 150 amp solar panel.
Drifter control panel easily monitors water and battery levels.
2 x Sirocco 12v fans in bed ends
Kakadu shade screen bed end covers
Sunbuster shade wall for the awning
Standard inclusions:
2 x 90lt water tanks
Truma reverse cycle air conditioner
Thetford 185L 3-way auto select fridge
J-tec off road independent suspension
Wineguard TV antenna with booster
Fusion CD player/Radio with Bluetooth
Tow secure break away system
Bayonet gas fitting
Graham 0468 478 213
$46,500
Shoalhaven Heads NSW 2535
Extras:
Extended draw bar
Bayonet gas fitting
Graham 0468 478 213
$46,500
