16' Series Drop down spare wheel carrier
AmandaBradly76
Mackay
Can anyone point me in the right direction to get a drop down spare wheel carrier for the rear bar of our 16.49-1 Expanda Outback?? I have sent a message to “burnsie” on this site, but have not had any response, so not sure if anyone else makes them?
19,516
I found a wind down underneath was better, I would just get dirty each time I dropped it when I had it on the rear bar and since one rarely needs the spare the argument of hard to get at doesn't wash.....I found it quite easy... Built it myself...
2,651
3,817
I was lucky he made mine but hes been off the fourm for a while i got it a few years back could easy get a few measurments off it it wouldnt cost a lot to get one made
Reactions: AmandaBradly76
19,516
Here you go Camec have one in their catalogue page 3........ so nip into your local mob......have no idea what they charge.
19,516
If you weld a box section over the round bar and Mount off that it will hold, did on my old 14.44 with no sign of the round bar failing.
AmandaBradly76
Mackay
Hi Bluey - thanks for your reply. Some pics and measurements would be fantastic Thankyou!
Macca_75
680
596
SE Suburbs, Vic.
The new vans are now coming with these standard from Jayco so surely (if you are willing to pay the Jayco tax) you could buy it as a spare part. Looking at them at the show you would need to weld a part to the under chassis though.
Reactions: 1DayIll
7,410
Here are a couple of pics of my rear spare conversion. I fabricated the bar and welded caps on each end and welded longer support pieces to go into the RHS under the van which allowed me to put an extra bolt in each side for extra support. It was held in the up position by a single pin with a spring clip holding the pin.DSC_4107 (2).jpg DSC_4108 (2).jpg
Reactions: 1DayIll
Chrisand Susan
19
11
How did you go with this I just made a full 50 x 50 x 3mm rear bar for my 16.49.1
coys 53
126
50
perth
Remove existing support and weld brackets across the a frame to suit wheel winch then lower and raise under and through to existing position placing tool box on a frame as required
