Curryhouse's Jayco Sterling 21.65 van
19,516
I was going to use brass fittings, I knew I had them but they were in hiding until the other day when I found them, plastic is doing the job now and I can't be bothered, will stick them in the van for Just In Case.
Reactions: Curryhouse
Curryhouse
179
195
Finally got around to finishing off one of the projects on my to-do list - making a modified jockey wheel / plate. Some time back I'd bought a cheap used ratchet type jockey wheel. Bought some suitable flat plate and pipe from a local steel supplier and finally with the help of a cousin-in-law with welding skills, welded the bits and pieces together. Overall, I'm happy with the result despite a couple of design flaws I encountered along the way.
Curryhouse
179
195
....and another little job off the project list (well, 95% of it). Had made up a pole holder a while back and finally got round to painting it and fitting onto the van. Now just have to paint the white straps.
Reactions: dagree and Drover
19,516
Plenty of time...................
Your way better than me with the jockey wheel, I just cut the bottom off and welded the plate on but found it jiggled around just as much so dumped it....all the movement was in the windy bit.
19,516
Wish I still had it as it would be great when Big Mal is just parked up at home.
