G'day again CR. First up, a dumb point I made in my above post. The internal roof is the awning which is vinyl, so it will still have moisture condense on it. We have a personal preference for canvas but if it gets dirty, it is more difficult to clean than vinyl (it can't be scrubbed like vinyl) and it is also heavier, a full annexe would be a couple of kilos extra.
I'm sorry I can't give you measurements for the annexe as we haven't got it yet but I will be able to measure the width it goes out to. The only problem is we are off in the morning and wont be home till Tuesday sometime and will be off the web until then. I'll post is when I get back unless Moto can give you the measurements beforehand. The guy measuring up told me that the side wall slopes out a bit, so is wider at the bottom than at the top but I don't know by how much.
The price was $2650 and includes the anti flap brackets at each end and a centre roof support, a window and door at the front, a large window at the rear and a single large window on the side wall. It has vinyl up the walls to the windows and is zippered at each corner so all the walls can be rolled up or taken out on poles to make awnings. Windows have mesh under a rollup flap as does the door. Also the draught strip along the side of the van goes up the full height of the aluminium strip down the side (OB model). Finally, as a show special, they included a porch out the front.
As for Port Campbell, we have never been there so I guess you are mixing me with another member.
