Hey guys,
Today I found out the hard way that the suburban hot water system is not always sealed around the body/wall of the van. When I go to change the anode I like to flush the tank with the garden hose and this time round water has managed to leak in through the bottom corners of the hot water system, into the cupboard and run down the floor under the oven and ensuite before finally running out of where the hoses come through the floor at the RHR corner of the van. After pulling the vanity off the wall, I've attempted to shove tea towels under the shower floor to soak up any water that remains plus run a fan heater into the cupboard to help dry it out. So a five minute anode change has turned into a nightmare. After this is sorted I'm going to seal the corners of the HWS with some sikaflex. Don't let this happen to you.
