Exterior Anti Flap Kits (AFK) - which model and what should I look for?
Wildtrak
5
Mackay
Hey all,
So the new 20.64.1 OB has been on 3 trips and we are slowly learning what we need.
Next on the shopping list is a AFK.
We have a 17' awning so after advice on which AFK would be suitable. I'm not sure what I want, need or to look for.
This is the email on prices etc I got from Annexes Wife Australia
I have listed the supply prices individually below as each can be bought separately and then added to.
Freight/Fitting prices depend on postcode.
If you don't have the Fiamma Fast clip system (Anti-flap kit) it is $505 and possibly 1 rafter $140.
Camper room walls $1700 (3 walls) Walls are the same design as our Captain cook annexe walls with 3 layers: Mesh screens, clear PVC zip down covers and canvas lay for privacy. We can make them to suit your Fiamma awning.
Camper quarters $880 (sometime called the extension room) Pics attached. Comes with shade cloth floor.
Camper ensuite approx $550 (proto-type) with the 2 doorways from inside.
Fiamma Porch $490, comes with 4 poles., 3 spreader bars, centre rafter and bags, ropes and pegs.
Please do not hesitate to contact me for further information. The facebook post has been extremely popular and I am trying to keep up with responses.
Kind regards, Fiona
Reactions: Macca_75
Tuppy
23
13
70
Hey all,
I am convinced I want the actual bars and not just the little clips. I want to future proof the purchase as we aren't sure what we want in terms on an annexe, etc (We have a shade sail which is working great - not sure if we will just end up with another privacy screen for the back or end up with a full annex) so I am looking for a kit that includes a sail track - I remember seeing a kit that actually had 2 sail tracks. What would I need that for?
So......
After recommended brands, personal feedback and hints of what to lookout for when looking/assessing different brands. Any options I could/should consider? All advice appreciated.
Also are they a pretty easy DIY or is it recommended to get a specialist to fit them?
Also, if you have pics of yours setup that would be great.
I went with Aussie Traveller and haven't regretted it. Also, as my van is black/silver with a [mostly] black awning, for an extra $70 thhey powder coated thhem black...they look great!
I wish we knew we needed them as much as we do - I would have just got them installed from new. Lesson learnt.
Thanks guys - Aussie Travllers from Jayco it is.
The Aussie Traveller AFK come with quite good instructions. Ive fitted them and it an easy job once you come to emotional terms with drilling holes in stuff. But if its not you driling the holes carefully, it will only be someone else not so carefully.
If you have any doubts at any point just stop, grab a few pics and posted it up here.
Im SE suburbs, your welcome to come and have a look at mine
Reactions: bigcol and dagree
Macca_75
680
596
SE Suburbs, Vic.
Thanks @Crusty181 - might take you up on that offer. Did you fit them yourself?
Reactions: Crusty181
19,546
Bevel the holes you drill, the professionals just rip the hole in the barrel so in time you end up with little holes in awning, I have little gaffa tape pads over mine to stop any catching, don't lose any bits of your bars either, other than the plastic bits they don't sell parts.
Prefer shade walls for ends with velcro then you don't need to put up the AFK for short times.
Macca_75
680
596
SE Suburbs, Vic.
Ok so I got the brackets fitted OK once I got over the nerves. I did have to unscrew one of the main screws holding the annexe track on and reuse it for the bracket.
Anyway I am confused on the hole in drum. Do I extend it and then wind it back in 90 degrees (so the pull cord is now facing the van)? The pic is taken from the rear of the van looking forward. Is this the correct location where I should drill?
Bretthar
7
9
sydney
From your picture the drum position looks about right, you want the slot below strip light at 3 o'clock position. Biggest mistake is rolling awning all the way out and it forms a bit of a gutter to trap water, you need to wind it in a few clicks. I just installed a set on mine and where your spigot is looks to be about where I drilled my hole, also make sure you drill at same angle spigot is at
when you have it fully extended - the awning
bring it out until the flappy bit (bottom of your pic) is at say 11.50/11.55 (on a clock................... dyaunnastand??) that way the seam is not at 12.00 and water can flow off the top of the awning
Reactions: Drover and dagree
Doc
158
313
Hobart, Australia
Hi @Drover ,
There are two schools of thought on that paradigm.
1: extend the awning all the way
2: leave it slightly rolled up (as shown in your pic)
Awning manufacturers recommend extending the awning all the way. One of the reasons being that if you retract the awning slightly, all the load is placed upon the ratchet mechanism.
There are many people who recommend leaving it slightly retracted - for various reasons such as water runoff, debris (eg leaves) runoff.
Personally - I extend the awning all the way. I've never had an issue with water runoff (leave one side slightly lower than the other).
Reactions: Bellbirdweb
I recall the instructions were pretty good with measurements etc, but in the absence of that the sail track in the drum faces the van dead flat with the slot central, pretty much as you have it, bit hard to be precise in your pic but you may have to roll the slot up a little bit, to centralise it You shouldn't roll any further out because annex walls need to line up in that corner and rolling it out further pushing the full annex wall away from the side wall that slides into the AFK arm
The short answer to your question is yes, mark the correct position for the hole and roll out the awning to give your drill access to the mark. As you can see in your pic the AFK slides into the drum on an angle so its best to drill the hole on an angle, a little bit shallower, to help the AFK side in and out easily and stop the AFK binding in the hole. To do that start with a small drill bit drilling straight in and working your up with larger bits. The last 2 drill bits angling them the bit to tamper the hole toward the AFK's insertion angle. The angle of your hole (that just sounds wrong) doesn't have to match the AFK insertion angle, just a bit to help stop it binding
19,546
First up @Doc not my pic it's macca's, but have seen a few variations, having used mine a lot it actually has 2 lots of holes, one set for the fully extended which I find I don't care for that much as the dust and dirt collects, the other is as G Daddy described is at 3.00 o clock, this position seems to put less strain on the awning at the clamp end, no dust and leaf collection and in a good gully raker the water gets away quickly........if you have led awning lights on the barrell I suppose they would define the position as well.
Reactions: bigcol and Dobbie
19,546
Oh and make sure you pull the awning into the clamp before you lock it down so you have it in the right position when you mark the holes and brackets position, have seen the odd one which had sloppy awning as the holes/brackets were wrong.
Reactions: bigcol and Macca_75
Jayco dealer did ours and then the Annex people drilled new holes as the Jayco ones where not right :(
I noticed when I first put up the AFK it was setup different to my previous Jayco they used the hole where the cable goes in for the LED light as one :(
They also put on our Bike rack after build and only secured it with screws so it fell off almost. I assume they had the new guy do our van :(
You will see a few vans out there with two sets of holes :(
