We have had our on road 17.56 for nearly 3 years now and have come to grips with most of its idiosyncrasies.
However one thing that continues to annoy me is the drop jacks.
I have found that they are only really effective when they are in the vertical position (and not on other angles).
Yet the jacks length is 300mm and the clearance to the (level) ground is 250mm.
Consequently they can only be placed in the vertical position at one end if you are parked on uneven ground or one one side if you have the wheels on ramps. Are the jacks on the off road model the same size?
Does anyone else have this constant annoyance or has some else found a solution.
And does anyone know what the two pieces of Velcro attached to the canvas bed ends (near where the hockey stick sits) are used for? I have laid in bed and considered all options but am yet to guess the reason.
